Check ESC dash light is on!?
Have a 2012 jkur. Bout 45 min in to our ride home from 2 days trail riding the check ESC light comes on still drives fine. Cruise control won't work since the light came on. Just wanna know what it could be and how to fix it. Please help!!
^that. Also make sure your battery connections are tight. You may have bent or moved something on the trail. If your steering wheel isn't straight then adjust that and you should be good.
Originally Posted by rob_engineer
Are you still on original battery? Our dash lights can do whacky things when battery is going bad or connections are loose.
Bought it may of last year I assume it's the original battery just shy of 40 thousand miles
Can't help but think I messed something up on the trail since it happened not long after we left from trail riding
It's also a manual if that matters
Originally Posted by 14Sport
^that. Also make sure your battery connections are tight. You may have bent something on the trail. If your steering wheel isn't straight then adjust that and you should be good.
Here's a link...
Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Yeah that's your problem. It takes 5 to 10 minutes to adjust it.
Here's a link...
Here's a link...
No problem. That's why we're all here.
Disconnect the battery negative terminal for 10 minutes if you don't have a reader that can clear it. Or you can wait and it will eventually go off if no other problem exists.
