Clips
Old Sep 25, 2008 | 12:34 PM
hawgrider1200's Avatar
Question Clips
those damn plastic clips that the metal bar on your rear window when u run your soft top. Mine will not stay on period. So I went to the dealer today cuz I read somewhere on this forum that Chrysler had a TSB about it and had redesigned the clips. Service manager would not even admit that. They are gonna order new ones for sure but he says there is only one way to put em on and they won't work any other way. Said I might have bent the lip where the clips are positioned. How's that cheap plastic gonna bend that metal????
Old Sep 25, 2008 | 05:45 PM
mkjeep's Avatar
Just ziptie them on, write-up somewhere on here, they will not pop off after you do this.
Old Sep 25, 2008 | 06:37 PM
BlackNorthernJK's Avatar
or if your more adventurous there was another thread on this some time ago...you could drill 'em and screw 'em down...that is if your not opposed to drilling holes in your rig
if you are look up one post
I've never had a problem with mine at all.....not trying to be an ass but did you check to see that they are seated good and proper
Old Sep 26, 2008 | 01:23 AM
TINMAN080's Avatar
IF I remember correctly, (at my age not likely-cut me some slack here) I believe my brackets did not just ''snap'' on, they had to be inserted and then kind of rolled forward to hook and grab the inner lip. Anybody else recall this?
Old Sep 26, 2008 | 03:46 AM
thanks for the quick replies fellows. I don't know how long it'll take to get the new ones but I reckon I'll deal with it untill I get new ones. Maybe the new ones will work correctly.
Old Sep 26, 2008 | 02:10 PM
katsumotology's Avatar
Default Zip Tie
zipties work great. I had the same issue. No problem after zip tie. I keep the ties on(around) the clip for the summer. Then, I cut them when I put the hard top back.
Old Sep 26, 2008 | 11:19 PM
Brad2893's Avatar
I have been using my softtop since April steady and no problems with the clips. Try new ones, if they pony up with them. I hate the idea of drilling when it's not really necessary.
Cheers.
Old Oct 10, 2008 | 10:19 PM
Default clips
got new clips work real good. Dealer did not charge for them either.
Old Oct 11, 2008 | 04:25 AM
2drREDROCK's Avatar
Glad the new ones worked
I was lucky with mine
Old Oct 31, 2008 | 10:43 PM
gdeal's Avatar
Default Chrysler TSB
what is the TSB number for the Jeep Wrangler Soft Top Rear window bad clips issue? I want that number so I can take it to my dealer. They didn't help me with this before. And if they came out with something new, why didn't they do some kind of recall. It is BS like this that makes me miss my Imperial Japanese vehicles.
