''Are you sure you 100% sure you unraveled your clockspring? Are you getting lights on the dash? You would have had to rotate your lower steering shaft at least one full revolution or more with the gear box disconnected to encounter any problems after installation. Part of me thinks the steering shaft is rubbing against something or it's not situated in the firewall properly''
I turned it steering wheel anywhere from 3-4 turns in maybe each direction checking for play from the shaft to the steering wheel while the gear box was off, then when I hooked it all back up, while bleeding my gear box i hear alot of noise in the steering wheel. Crunking cracking type noises for I'm 95% that it's the clock spring, my air bag/ esp/ bas lights are all on and no horn. So like I said I'm pretty damn sure that's my problem. Now another problem I'm having is the wheel seems to be losing center like it has some play in it as your making a left and right turn, can this also be caused by the clock spring being broken? |
Originally Posted by ink42o
(Post 1626094)
I turned it steering wheel anywhere from 3-4 turns in maybe each direction checking for play from the shaft to the steering wheel while the gear box was off, then when I hooked it all back up, while bleeding my gear box i hear alot of noise in the steering wheel. Crunking cracking type noises for I'm 95% that it's the clock spring, my air bag/ esp/ bas lights are all on and no horn. So like I said I'm pretty damn sure that's my problem. Now another problem I'm having is the wheel seems to be losing center like it has some play in it as your making a left and right turn, can this also be caused by the clock spring being broken? http://i294.photobucket.com/albums/m...bagsensors.jpg If the wheel has play then you're looking at the gear box (can be adjusted by the adjusting screw on top of it), the steering shaft, loose retaining bolt where the lower steering shaft meets the gear box, or some kind of trackbar problem. |
''If the wheel has play then you're looking at the gear box (can be adjusted by the adjusting screw on top of it), the steering shaft, loose retaining bolt where the lower steering shaft meets the gear box, or some kind of trackbar problem.''
Once again, I'm pretty sure it's not the gear box, because I just sent it off and got it back from PSC. And the guy's there told me when it comes back it is just a plug and play from them, and I haven't done any wheeling so I know I haven't re-damged the gear box. Now the only thing I can think of from this is that after a few miles on the new gear box parts may have wore in a little and then need some adjustment from that, but I will but in a call to PSC later to day to find out if that's the case. |
i seem to have a clicking when i turn the steering wheel, the sound comes from somewhere in the steering colum, i think where the steering wheel rotates, im starting to think there is a problem with the clockspring but i have no lights flashing up.
Could this just be soemthing rubbing instead, a little squirt of lube might fix? |
(Post 1625613)
And the one thing I was worried about is the air bag going off in my face if I pull the steering wheel myself.
This write up will get you to the clockspring. Hope it helps. https://www.jk-forum.com/forums/show...install+cruise |
as stated above. disconnect the battery. air bags have changed drasticly, they just don't go "off" anymore.
