JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Stock JK Tech (https://www.jk-forum.com/forums/stock-jk-tech-12/)
-   -   Clunk noise (https://www.jk-forum.com/forums/stock-jk-tech-12/clunk-noise-185023/)
Hoot Jul 5, 2011 08:04 AM
Clunk noise
Whenever I start out I hear and feel a clunk noise from the rear end of my 2010 wrangler sport. Anyone know what it could be?
Joisey Jul 5, 2011 08:30 AM
I have this same issue, It's your spider gears, something was set up wrong and they have chew'd themselves up. To conf this you can pop your rear dif cover and take a look. More than likely they look like someone took a chisel to them.
I think my factory LSD did this to mine.
Should be covered by warrentee.
Hoot Jul 5, 2011 09:47 AM
Thanks, will definitely have this checked out...
GeoJeep33 Jul 5, 2011 12:25 PM
I had a clunk upon starting, from the rear. It turned out to be the right lower control arm bolt on the axle end was loose. I had adjusted a spring a few days before and I suspect I missed it when I was tightening things down.
© 2026 MH Sub I, LLC dba Internet Brands
