a clunking noise...
a clunking noise...
when I put the Jeep into first gear and move forward quickly or come to a stop fairly quickly I hear a clunk that sounds like play somewhere in the drivetrain. It sounds like it is just behind me in the center, so I am thinking it's possible that it's near the transfer case. At first, I thought it was just one of my control arm bushings but I've since inspected and replaced all of them. For me to get a look at the transfer case is a pain in the ass since all my heavy Rock Hard skids connect to the transfer case skid and I'd have to remove them. If anyone has had this before and knows what it is likely to be, it would be helpful before going through the trouble of removing everything and then finding out its something else.
Originally Posted by Battlefrog
Did you make sure everything is torqued to specs... Also, check your drive shafts...
Is there anything to inspect besides just visually? I mean checking for play somewhere? Something that moves more than it should?
I'm pretty anal about torque specs and I am always under there inspecting stuff. I didn't see anything obvious with my driveshafts. What should I look for? There's rubber bushings over all the moving parts on the stock driveshafts.
be sure to let me know if you figure it out. I'll do the same.
Do you have an auto? If so put it into drive from park, and see if you can hear a clunk, then shift it into reverse, does it clunk now? If so you have a u-joint that has gone bad.
As well make sure that all the things that you have in the back are secured down, and not rolling around. Ask me how I know that one , don't forget to look in the jack cubby hole.
What was the last thing that you installed and started hearing the noise look there as well. Check the mounts for the exhaust system, they break and allow it to move around more then it should. Check your shocks. As well make sure the rear tire is firmily in place.
Trying to think what else......
Does anyone know how the transfer case is mounted? Should there be a little play between the TC and the frame? While I was trying to get my driveshaft out I noticed the whole TC could wiggle a little when I pushed on the flange. felt like it was mounted on rubber joints or something. I assumed it was normal.
I am getting a clunking noise when accelerating from stop, and occasionally while accelerating out of a turn at about 10-20 mph. I have an automatic. I recently installed the TF Spring leveling kit. I have loosened all of the suspension components, after checking for play, checked the bushings, and the torqued back to spec. The noise is coming from behind and to the passenger side. When I was standing next the jeep and had my wide accelerate from a stop heard the a creak followed by a clunk. I was unable to pinpoint the noise.
The rear is only lifted and inch, I don't think it's the suspension, not because I installed it, but because I don't hear it when going over the speed bumps in our neighborhood. Or any other bumps at higher speeds.
It did not start until about a month or so after installing libeling kit. Haven't heard it in reverse, I will double check though.
