Coolant leak jeep jk 2008
I have a coolant leak that seems to be coming from two different locations on the jeep. It is a 2008 JK 3.8L, 137,xxx on it. I pressure tested the jeep last night for 30 minutes or so and had the psi drop maybe 1.5 lbs. I am noticing a leaking coming from the back of the motor down to the bell housing and collecting there. I also have a leak from the front of the motor which seems to be coming down and collecting on
The oil filter. I checked the oil and noticed no milky residue inside. Any suggestions as to what it may be? I am thinking intake manifold.
Rednroll's thread here might be helpful to you....he's going through coolant leak issues in the last week as well.
https://www.jk-forum.com/forums/stoc...e-area-343770/
Do the upper gaskets along with the bottom, while you're at it.
It was $85 of gasket replacement parts but a sh*t load of work replacing them.
Sounds like the same as my problem. Step-by-step provided in my thread if you're a DIYer. Hopefully, you don't run into the same manifold bolt problem as me.
