Cragar Rims??
Old Aug 29, 2007 | 10:31 PM
GhostMercury's Avatar
Default Cragar Rims??
I am looking at getting some cragar rims Click Me and i was wondering what is the biggest size rim and tire setup i could run without causing any issues like rubbing on the stock suspension setup.
thanks for the help guys i cant wait to start exploring the site more.
Last edited by GhostMercury; Aug 30, 2007 at 10:47 PM. Reason: please refrain from posting direct links to non sponsoring vendors
Old Aug 29, 2007 | 10:33 PM
I would like to get a 17 inch rim if possible.
and to give you guys an idea on the look i am going for here is a picture
Click Me
Old Aug 29, 2007 | 10:53 PM
FRDesign's Avatar
I would suggest going to a 15" rim with no lift, that way you get more sidewall so you can air down.
33x10.5R15 would be good for no lift.
Old Aug 30, 2007 | 06:40 AM
Jake_Blues's Avatar
If you want a 17" wheel, then your best bet would probably be to find someone with tires pulled from a stock Rubi (32x10R17) and run those.
However, if you want the look of that lifted Jeep, then you're probably better off going with a smaller wheel like a 15", it will make your Jeep look a little bigger/higher by comparison. You could probably get away with a 33" tire if you go with a little higher back-spacing to prevent rubbing.
-E
Old Aug 30, 2007 | 07:48 AM
so if im reading this correctly your saying go with a 15x10 inch rim?
Old Aug 30, 2007 | 09:03 AM
Paul R's Avatar
If you are going with a tire which is 12.5" wide or less, I would go 15x8. Wider than 12.5", go 15x10. You could use a 15x10 with a tire 11-12" wide, but you stand more chance of popping a bead if you air down.
Old Aug 30, 2007 | 09:27 AM
sweet info. i have been on like 3 car forums and this one deffinatly has the best people.
Old Aug 30, 2007 | 10:09 AM
jetsfan28's Avatar
question: do the 15's clear the calipers? I thought they did not.
Old Aug 30, 2007 | 06:40 PM
Blackrat's Avatar
Click Me
If you are going for that look... why not just get a Budget Boost? They are just a set of simple spacers that go on your springs. I have heard some good things about the Teraflex 2.5" boost and then you will be able to get 35" tires. Most of the reviews I have read say that there is really no difference in the road manners with the boost (since it uses the stock springs and shocks). Plus, Teraflex kit is only $225. Then you can actually get that look in stead of trying to replicate it.
Old Aug 30, 2007 | 10:25 PM
im not trying to make the car look like its lifted. i just want to fit a decent size tire in the wheel well while keeping the stock height. I like the tucked look in cars and trucks. I dont plan on climbing HUGE rocks just yet so some big tires will do just fine.
