Dented oil pan. Replace or leave?
1 Attachment(s)
Went wheeling yesterday and got hung up on a tree stump. Dented the oil pan pretty good. It's not leaking so my question is should I replace or not bother. Is there anything that hangs down right there in the pan that may have got bent as well?
Thanks |
Replace and get a skid plate.
i would replace as well
Replace as you may not have problems now you will later on.
Originally Posted by Mad Dog 21
(Post 4241682)
Originally Posted by Eandras
(Post 4241691)
(Post 4241682)
Replace. I believe most oil pans r designed or have baffles so the crank doesn't cause oil aeration
There are no baffles in the bottom of the stock pan but I think the stock pickup is in that area.
Not that they're to be found anywhere, but the Benchmark Designs pan is the business. It's solid plate all the way around and that is welded to a flange that's bolted to your pan. |
(Post 4241723)
There are no baffles in the bottom of the stock pan but I think the stock pickup is in that area. Not that they're to be found anywhere, but the Benchmark Designs pan is the business. It's solid plate all the way around and that is welded to a flange that's bolted to your pan.
