differential cover change
All,
I am going to buy a new set of arb diff covers and am not sure what goes into changing them out. Any hints, tips, or directions would be appreciated! |
1 Attachment(s)
Check out WOL's write-up.
http://project-jk.com/jeep-jk-write-...r-installation Also hate to be that guy, but if you do a search for differential. Theres tons of threads with pics,write-up's.ect https://www.jk-forum.com/forums/sear...archid=4211633 |
Awesome, thanks all!
Just did swapped my differential covers out for the ARB ones. Follow WOL's write up and you will be fine. I used lube lockers instead of RTV and it made it even easier.
Great thanks for the tip on the lube lockers. It was hard to find this topic as I usually use the android app, so the search is kinda unreliable. I appreciate all the feed back!
Originally Posted by jsears
(Post 2334622)
With my Riddler D44 cover i torqued to 25ft lbs and it hasnt leaked yet. I believe lubelocker sayd 35ft lbs but peoples bolts have been snapping at that torque
Originally Posted by Croce
(Post 2335320)
1 Attachment(s)
Originally Posted by will16
What did you torque your bolts to with the lube lockers? This is the stock diff cover and bolts? |
Is everyone using 2 quarts in each diff, front and rear? When I changed fluids the first time with stock covers, I only used 3 quarts and the oil was spewing out of the fill so I know they were full. I have Soild covers now and plan to do them this weekend. Should I buy 4 quarts of gear oil? 2 front, 2 rear?
| All times are GMT -8. The time now is 05:49 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
