Differential oil level
I was checking the oil level of my front differential (Dana 44), and the oil is not at the same level of the hole of the drain nut.
I put my small finger into the hole, and the oil level is about 1/2 inch lower. Is it okay, or should I add some oil ???
Assuming the Jeep is on level ground, and you have a stock differential cover:
The oil level should be at least as high as the bottom if the fill hole.
Top it off.
I guess I don't understand what you are asking in the first post. I thought you were saying the fluid level was 1/2" below the fill hole. My response was very clear what you should do if it is true your fluid level is 1/2" below the fill hole.
Agreed jsut add some until is starts to come out . put a drain pan underneath and wait until it stops. Cap it up
That's how it used to be done. That procedure will likely result in an overfill condition. The differentials have a fill capacity listed in the owner's manual. It may or may not end up coming up to the fill hole.
