Door hinge bushing necessary ?
I finally succeeded in removing the doors on my JKU. 2 years of winter Canadian driving made them very tough to remove.
While doing so, the driver door bushing were completely shot. I had to remove the bushing of the driver side door. I lubricated all the pins with lithium grease and reinstalled them. Do I need to reinstall new bushing ? Are they mandatory or should I remove them all ? What is the drawback of running without them ? Thank you |
Originally Posted by CanadianSahara
(Post 3118376)
While doing so, the driver door bushing were completely shot. I had to remove the bushing of the driver side door. I lubricated all the pins with lithium grease and reinstalled them. Do I need to reinstall new bushing ? Are they mandatory or should I remove them all ? What is the drawback of running without them ? Thank you You're probably ok for the very near term but I would replace the bushings asap. Consider the upgrade to delrin bushings. There are several threads about them on the forum. Also, take a good look at the alignment of your doors. There may be other reasons for the difficulty removing them. |
Check out Magnitude Engineering for replacements that should last alot longer the oem ones
| All times are GMT -8. The time now is 03:00 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
