door lock kit install
Took a idea from Ford. actuators are install inside the doors. Does require some disassembly but worth it.you have to pull the window regulator panel and the door latch . Install the lock actuators on the inside lower vertical corner. This is a direct rod attachment and not some cheap attachment with screws to clamp on to the outside lock quite witch bends and runs the wire on the handles. Will post rest of pics later in order. Power window and auto start next.
