Driver Door won't lock or unlock with key
Old Jun 23, 2008 | 04:03 AM
xUnlimitedx's Avatar
Default Driver Door won't lock or unlock with key
Has any one run into this problem before. I don't have power locks so i use the key quite often to unlock the driver door and yesturday after a rain storn i went to unlock my door and they key went in not all the way at first but then i wiggled it in and then in wouldn't turn. I finally got in from the passenger door unlocked the driver door and then tryed to lock it with the key with the same problem went all the way in but did not turn. Has anyone had this problem before? Should it be covered under warranty?
Old Jun 23, 2008 | 04:53 AM
Geeper4x4's Avatar
No. I haven't had this problem on my JK.
Yes, this should be covered under warranty.
Old Jun 23, 2008 | 05:00 AM
Rubidonn's Avatar
Warranty...
Old Jun 23, 2008 | 05:09 AM
Offroadme's Avatar
have you taken your doors off at all make sure the plug is in all the way if you have taken the doors off
Old Jun 23, 2008 | 06:01 AM
Rubidonn's Avatar
He's got manual door locks.... sounds like a tumbler issue or maybe one of the rods inside the door has malfunctioned.
Old Jun 23, 2008 | 10:45 AM
TMC's Avatar
TMC
Yes I did have this problem! the dealer replaced the locks but I see it happening again. the only sugestion the dealer had was to keep it oiled.
I thought my locks froze last winter and that may have been what has caused it. Either way the dealer did replace them (both doors)
Old Jun 23, 2008 | 01:36 PM
cool thanks guys i'll make an appoinment and drop off my doors and ill go cruzing doorless till they have it fixed no point in sitting in the dealership and waiting.
