egr valve
Old Dec 10, 2012 | 01:37 PM
dougehr1's Avatar
Default egr valve
Had check eng light code 404 took to dealer they said egr was bad and wouldnt cover it in warranty.so decided to change it my self.took about 30 min to takw inner fender out and remove 3 out of 4 bolts. The last bolt took about a hour and half to remove.i have a auto and the tube and fiewall in the way.glad that job is over.good news is i did save about $300.
Old Dec 15, 2012 | 05:06 AM
Bxjk's Avatar
Just got the same bad news from my stealership.
I'm gonna pm you
Old Dec 15, 2012 | 05:51 AM
Rico's Avatar
Can you tell us why it wasn't covered under warranty? Is your vehicle beyond the warranty period ?
Old Jan 2, 2013 | 12:58 PM
Bxjk's Avatar
My service guy said my warranty just expired. So I said no worried I have an extended warranty and he said great. Let me call to see if the part is covered. 2mins later he says no its not covered.
I say BS all these warranties and nothin is covered. I even have the lifetime power train warranty. Can't wait to try and use that one.
Oh well. I will be ordering one ASAP and spending a day installing
At least I know it will be done correctly
Old Jan 2, 2013 | 02:02 PM
oldtimejeep's Avatar
Default EGR valve
Should be covered under emission warenty if under 80K I believe. Check your warrenty book under emissions.
Old Jan 2, 2013 | 07:39 PM
07tungsten's Avatar
Nope it's only covered under 36k miles. Mine needed replaced at 40k. I called Chrysler and they covered it for a $100 deductible since that was too early for it to go bad. Hey at least you're not out $450!
