engine clearance
Old May 19, 2010 | 05:56 AM
Default engine clearance
can the piston hit a valve if the timing chain broke.
Old May 19, 2010 | 07:09 AM
ronjenx's Avatar
Yes. The 3.8 is an interference engine.
Old May 19, 2010 | 07:34 AM
Locklain's Avatar
That is no good.
Do you know if Chrysler uses a chain or belt in these motors?
Old May 19, 2010 | 07:35 AM
ronjenx's Avatar
Originally Posted by Locklain
That is no good.
It is a chain.
In my opinion, that makes up for being an interference engine.
Old May 19, 2010 | 07:38 AM
Locklain's Avatar
It is a chain.
I agree, if it were a belt I was going to cry myself to sleep since I would be rolling around on that "questionable" life expectancy soon.
Old May 19, 2010 | 08:39 AM
Pape's Avatar
just out of curiosity can you name a car that use a timing belt in a engine 6 cyls and more ?
my believing is today all 4 cyls use belt and anything bigger use chain.
Old May 19, 2010 | 08:50 AM
ronjenx's Avatar
A quick search revealed:
2002-2006 Toyota Camry 2.4L 4 cylinder has a chain.
2004 and newer Toyota 3.0L and 3.3L V6's have timing belts.
Old May 19, 2010 | 09:17 AM
OpenTrackRacer's Avatar
Keep in mind that the 3.8 liter is a overhead valve design with the cam in the block. The camshaft is closely coupled to the crankshaft by the timing chain and activates the valves via pushrods. Timing chains rarely fail.
Old May 19, 2010 | 09:46 AM
Grant09's Avatar
I didn't realize that the 3.8 still had a pushrod design. Seems most engines now days have the cams in the heads.
Old May 19, 2010 | 11:39 AM
Ultrasport's Avatar
Interestingly, the reason I have a Wrangler is because my 3.7 liter Liberty had a CHAIN tensioner failure (at 125K) and it took out all the valves. I traded it for a Wrangler Unlimited with the good old 3.8, pushrod motor.
Steve
