Engine dies the #19 fuse is blown
i have taken my 09 jk to the stealership both driven and towed due to #19 fuse blown they charge over $100. to put in a new fuse and then say they cant get it to blow to know what is the problem any suggestions .twice i had to have it towed when i would replace the fuse it would blow when the engine started and blew the fuse , 6fuses later i called a tow truck the stealership said there was no problem after they replaced the fuse (TOTALLY GETTING AGAINST JK AND THE PROBLEMS ) i love my jk just hate not being able to take it anywhere feel like a caged animal thanks all .
Looking in my 2011 owners manual there are 2 #19 fuses in the PDC. One is J19 and the other is M19. J19 is a yellow 60 amp fuse and M19 is a 25 amp natural color fuse. Do you have more then 1 #19 fuse? If so which one is blowing? The M19 is the ASD (auto shut down) fuse. Remember this is on a 2011 so yours might be different. Not having the service manual it is hard to say what the fuse controls. The ASD I think controls the fuel pump among other things. Maybe the dealer could print out the electrical diagram for that circuit for you.
I worked on a 2004 grand Cherokee awhile back blowing the asd and fuel injector fuse
The local dealer charged the guy over 1000$ and weeks trying to fix it
I got ahold of it and found the alternator was bad shorting that circuit out
the fuse is m-19 ASD is the right one i was told to hook up my diagnostic computer and record what the electrical system is doing, so they can fix it ,My computer only records for 1 1/2have my computer hooked to it every time i go any where they want me to record what it is doing , my computer only records for 1 1/2 mins at a time tall that to and officer see what award you get ,( sorry just vented ) i am up for any thing i will try every suggestion . thank you any and all help
I think I would start looking at the wiring for the injectors, fuel pump and alternator especially around where the harness flexes when the motor torques. It could also be a bad PDC. I think there is a good write up on Jeepforum about taking it apart. I will see if I can find it.
Here is the link: OEM TIPM Study - JeepForum.com
ok still found nothing , till yesterday , fuse 19 blew again and while i was replacing the fuse i touched the top of the relays and they were all so hot that i took my hand off immediately , went to the dealership told them and they told me it was normal but they will get back to me monday why would and intire tipm be hot enough to burn someone ?
High resistance will cause things to become very hot. If all the fuses were hot I would think there is a problem with the main cable/alternator or possibly a lot of corrosion inside the TIPM.
ty the jeep with my obd computer is going to the dealership today thank you again for all the help i will post when we find the problem have a great day
Check the fusebox to chassis ground. If other relays are hot, the circuits could be backfeeding and grounding through those relays because their real ground is too high resistance.
