Engine Heating Up - Emergency HELP!!!
thats the radiator hose connecting the the thermostat housing at the engine, its boiling hot because your thermostat is stuck closed. You could check to see if the radiator feels hot or if the fluid level rises in the overflow tank. You can see where it says cold and hot on the drivers side of the white plastic tank.
It should be covered by warranty. I wouldnt drive it like that though.
you can also check for DTC codes
http://project-jk.com/jeep-jk-write-...what-they-mean
Are you guys gettting snow up there tonight? Will that make your trip longer? I would be watching that temp gauge big time, also will you have hot defrost to keep the windows clear? I see you have the 6spd, try and keep the RPM's about 2000 or below, I've seen this stop a jeep from over heating that didnt have a working fan.
yeah, we're getting 5-8 inches of snow tomorrow - actually, on saturday, i was driving on highway with RPM about 2500 most of the time, and the engine temp is at normal.
Fan seems to be working fine, it's just overheating once I idle 5 min or longer. So, as long as i'm moving, the temp seems normal. I'll try to leave earlier to avoid traffic, etc.
Luckily, i usually don't need to do hot defrost since i'm parking in my garage tonight, so we'll see. I just need to make it to the dealer. Once i'm there, it should be good
So far, here is the verdict - bad thermostat and leaking head gasket. The dealer will know more when they open it up tomorrow - hopefully nothing worse than that. Either way, it's all covered under warranty
thats great they are going to cover it all.....hopefully there isnt any other damage from the head gasket being blown. Did they give you a loaner?
