Engine Heating Up - Emergency HELP!!!
If the thermostat stuck, then the engine's heat hasn't got anywhere to go hence the weak point will fail.
I can't remember if we have a cast iron block and alu head - if so the different rates of expansion will cause the failure at the join (head gasket) under these stressful conditions. Even if it is alu:alu the head gasket is likely to fail.
You're lucky (I hope) if it got too hot, the alu head is likely to warp at the mating surface to the head-gasket requiring it to be machined flat again - I'd hope they measure the flatness when they take the engine apart.
Having said that I just added a thermostat to my trail spares list.
Yeah, i think the failed head gasket was from the failed thermostat. I guess it was a good thing i was waiting for somebody this weekend and let my jeep idle for more than 5 min. Or else, i would've never find this out, and it might be to late then.
Still haven't heard back from the dealer, but hopefully nothing worse than replacing head gasket - no crack head or something. At least they're all under warranty. I just hope that they do a good job fixing it.
One allowed the pressure to build up until the top hose blew off. This was before the days of recovery tanks.
I know you can specificly buy fail open themostats. They cost more. $8 vs about $4 last time I bought them.
I believe if they failed in the open position the vehicle would not overheat, failing in closed position will make the antifreeze not circulate threw the radiator causing the fluid in the engine to overheat.
Well, they said that they're having the Chrysler Rep to come out there and take a look at the problem. I mean, these are the same engine they used in their minivan, and they lasted for hundreds & thousands of miles before they go bye-bye.
