Engine light on after oil change.
Like so many others, for the past couple years my '07 Jk has been burning a lot of oil between changes. After much debate and researching on the Internet, I decided to try 5w30 synthetic instead of my usual 5w20 synthetic, as a lot of people say this fixes the burning issue. Changed my oil yesterday, put about 100 miles on it over the weekend and all of a sudden the check engine light lit up. Seems like an unlikely coincidence that it's happened right after the oil change.
Any suggestions? Should I just cut my losses and go back to 5w20? Do you think that will make the light go off? |
The oil change is most likely unrelated. The first thing you need to do is scan it and see what code/s pop up.
Turn your key from off to on position 3 times and report what code pops up on the instrument panel. On third on leave it in on position. No start is required, just on position. |
Thanks, buddy. It came back with a P0430 code. Looks like something with the catalytic converter? Maybe exhaust? As far as I can tell there are no exhaust leaks. Should I assume my converter is F'ed?
Originally Posted by CanadianJames
(Post 3678645)
I would also double check for exhaust leaks especially from your exhaust manifolds. I have change both of mine because of cracks as long as 2 inches.
It's got 120,000 kms, so that's about 75,000 miles. I hear some emissions stuff is covered up to 8 years? Would that include the cat and o2?
(Post 3678664)
Thanks, dude. Much appreciated!!!
(Post 3678685)
P0430 - Catalyst Efficiency (bank 2)
I would change the O2 sensors first before taking it to the dealer. By any chance do you hear a rattling from the mini cats? I had one on my WJ break apart and rattle. |
