Engine operating temp.
A little less than half-way on the gauge.
Now playing: ohGr - Timebomb
via FoxyTunes
via FoxyTunes
I had a fan problem ( I had a one speed by the factory not a two speed) Now with the correct fan (2 speed) MY JK runs up to 222 deg at 65 MPH with the A/C on! When they replaced my fan this is the temp I get now. The dealership said it is the correct temp for our Jeep!? I have The Scangauge ll now that is how I know!
Sitting in the barn idling, the temp goes up to 215, then the fan comes on and cools it down to around 195 and shuts off.
If I run the AC idling in the barn, the temp stays around 190 because the fan stays on.
It is probably hot at your location.
Is your JK lifted?
Is the front air dam removed?
Do you have any accessories mounted in front of the grill?
Has your radiator ever been under water?
I'm sure most people know this but just in case...
Back in the 80s the temp gauges swung up and down and up and down. You stop at a light they'd go up a bit, you start cruising they'd go back down.
Then in the 90s all the sudden cars started hitting operating temperature and holding it there perfectly! Once the engine warmed up the needle never budged. Wow some major break through in cooling systems must have happened right?
Nope, your temp gauge is now basically an idiot light. As long as the engine is within it's normal operating range the computer keeps that needle in the exact same spot. I don't know the exact numbers as it varies from manufacturer to manufacturer and probably even model to model. But as an example if the water temp is between 150 and 230 that needle will be dead center. In older cars 80 degrees would be quite a bit of needle swing.
So basically the stock water temp tells you 1 of three things. The engine is below the normal operating temperature range, the engine is in the normal operating temp range., the engine has exceeded the acceptable operating temp range.
