error codes P0457, P0740 and gas cap warning on
Old Oct 4, 2017 | 07:51 AM
forest42's Avatar
Default error codes P0457, P0740 and gas cap warning on
Hi all,
For the past few weeks my gas cap warning has been coming on so I replaced the gas cap four days ago. Two days ago the warning came back on along with the two codes mentioned above. I understand that the P0457 (Evap leak) code is probably related to that same problem but is there any relationship to the P0740 code?
I just replaced the gas cap and that didn't solve the gas/evap problem. I also saw that some people have had issues with a hose running near their battery getting abraded/corroded but my hoses seem fine. I put electric tape around them just to see and it made no difference. What else could be the problem?
As to the 0740 code, I'm going to drain/replace the transmission fluid as it looks old.
Thanks for any help
Old Oct 4, 2017 | 11:07 AM
jsukey's Avatar
Check this out to see if it’s what’s causing your CEL. That was the issue on my Jeep. No need to drop the tank. I spent .20 on a hollow plastic dowel, and $1 on an 11/64’s drill bit. I already had plastic cement for the job. It took me less than an hour to fix.
https://youtu.be/tHDetSZ-UEo
Old Oct 4, 2017 | 12:07 PM
rob_engineer's Avatar
I got the gas cap warning on my 2012 a few years ago. Turned out to be a small leak where a hose connected to the evap canister on driver side under the hood. I just tweaked the hose. The error code went away and never came back. That was over 3 years ago.
