ESP BAS & ABS & BRAKE dash lights ON
Recently while driving down the road I get a ding noise and the following idiot lights appear on the dash:
ABS
ESP BAS
BRAKE
Traction Control
Another wierd thing is my speedometer drops about 10 mph briefly.
Anyone have an idea of what's going on?
Thanks,
Steve
ABS
ESP BAS
BRAKE
Traction Control
Thanks,
Steve
As strange as it sounds, it could be your battery going bad. Our jeeps behave very strangely when the battery goes bad, including random lights on dash flashing on and off and speedo going whacky. Could also be loose terminals on the battery.
The following 2 users liked this post by rob_engineer:
Aussiecrd (10-16-2019),
Cordelia21 (10-20-2021)
I'll check the terminals, but the battery is only a few years old. Funny thing is, after I posted this... I parked and left for about an hour. I got back in and drove home, (30 minute drive) and the lights and beeping never appeared. I did notice it a couple of days ago. So... it's not continuous. Thanks.
Have you done anything to or with your battery recently or previously? Added aftermarket lights, accessories, etc? Definitely could be battery going bad but before that I would check tightness and correct installation of cables at posts. I had a loose neg and had similar intermittent dash lights and actions.
Watch "Replacing Wheel Speed Sensor on Jeep Wrangler Jk U1417" on YouTube
https://youtu.be/aMRaP40FH7s
Well, I went out this morning, popped the hood and discovered that when the dealer did the repair recently, they found a battery terminal nut to be a bit corroded, so they replaced it... and it was only "finger tight". They even left the old nut on top of the battery. I tightened it up and we're going to breakfast this morning... so will see if the lights come back on or not. I also noticed the battery is 5 years old! Time flies.
I hate to jinx myself but after a 35 mile round-trip to breakfast this morning, there are/were no lights or digging noises after tightening that loose cable connection. Thanks guys!
