ESP problem
Old Apr 5, 2011 | 02:18 PM
medic_23387's Avatar
Default ESP problem
Everytime I make a very sharp turn my ESP light comes on and it feels like it is slipping really bad. I do not have to be going fat for this to happen. What could be wrong?
Old Apr 5, 2011 | 02:36 PM
TX_Dave's Avatar
When driving straight, is your steering wheel straight? Or is turned in one direction or the other slightly? i.e., Is your steering wheel centered?
Have performed an alignment since installing your lift? There is a write-up describing how to do your own alignment. http://project-jk.com/jeep-jk-write-...-end-alignment
The alignment and steering wheel being centered do effect the ESP.
Old Apr 5, 2011 | 03:12 PM
drcre8tive's Avatar
could be a bad sensor, mud or moisture can get in there and mess with it, or it could be a pinched or pulled ESP line... does it happen only turning one way, or both ways? Crawl under the Jeep and look for the little electric cables that attach to the back of the brake... are they fitted correctly?
Centering the steering is not hard... though getting mine perfect was tough... also, sometimes the ESP light does not go off until you drive 50 miles after you center it.
Old Apr 5, 2011 | 09:29 PM
Westley's Avatar
Even though this is in the stock JK area... are you lifted? Often times lifts mess with the ESP for some reason. This was happening to my friends JK and his brakes wore out within a few months. He now just hits his ESPOFF button and hasn't had a problem since.
Old Apr 12, 2011 | 04:38 PM
It is lifted with 35's my steering wheel is off just a tad to the right and that is the way I turn when it happens. I will get it straight and see if that is my prob
