excessive engine braking?
Old Feb 10, 2014 | 03:19 AM
Kojack's Avatar
Default excessive engine braking?
Had my oil changed as well as more trans fluid put in to stop the drain back issue. could this be causing excessive engine braking or do you think its a brake caliper on the way out? 120k on my 2011.
Old Feb 10, 2014 | 08:41 AM
TxRdStr's Avatar
Saying running more tranny fluid than needed? Not a good idea.
Old Feb 10, 2014 | 09:47 AM
Jiblet's Avatar
What drain back issue?
Engine oil, transmission (auto??), and brake calipers are pretty diverse...
Old Feb 10, 2014 | 10:13 AM
rob_engineer's Avatar
You can test for a hanging brake caliper by stopping the jeep while on paved level ground. Let off the brakes slowly with it in drive. If it moves forward without applying throttle then the caliper is probably fine.
