Exhaust hangar contacting transfer case
On my '08 2 door, an exhaust hangar is contacting my transfer case and rattling. after a failed attempt to bend it out of the way, the current advice I've gotten is to have a muffler shop weld a new section in that clears the transfer case. Does that seem like the best way to go?
Bump.
Could you get a torch in there put some heat to it and bend it away ? Maybe muffler shop could for cheap price Instead of running a new section.
I was just under my 2dr all day today doing a clutch, how in the world is your exhaust near the case? I've got a 10 so the design didn't change anything.
Pictures?? |
I'll post a pic. The rubber piece is very torqued over
1 Attachment(s)
I can't be the only one that this has happened to
Mine sits massively to the framerail, try using a pry bar between the two and sliding it away from the case.
Once mine dries I'll get a picture for you. Is your exhaust on the hangers in the back correctly?? |
(Post 4164648)
Mine sits massively to the framerail, try using a pry bar between the two and sliding it away from the case. Once mine dries I'll get a picture for you. Is your exhaust on the hangers in the back correctly??
Originally Posted by AirJordan613
(Post 4164692)
Yeah, it's like this after a shop replaced an exhaust manifold. I took it back and they were unable to move it back over.
