Fellow Jeepsters, Help! Advice Needed!
Old Jan 27, 2008 | 06:46 PM
USNjeep81's Avatar
Default Fellow Jeepsters, Help! Advice Needed!
Long story short....
I went mudding earlier this afternoon and on my way home the Check Oil light comes on, so of course i'm thinkin "wtf" to myself and pull off the next exit and into an Autozone but by the time i get parked in a stall i can hear squealing and metal rubbing together from the engine, i know....not good.
So i get to looking around under the hood and my Oil cap is gone, go inside purchase a new cap, and 6 quarts of oil and add it in until it was in the Safe zone on the dipstick. I go get something to eat and let the engine cool off until i get back and can touch it with my barehand no problem....and now....it will NOT turn over at all, just get a single click is all.......what looks to be the problem?
Any help appreciated, i'm very sad and depressed at the moment as much as i love my Jeep......
Old Jan 27, 2008 | 06:56 PM
scouter4life's Avatar
Wow, that sucks. The only thing I can think of is mud/water got in the engine with the cap missing.
Old Jan 27, 2008 | 06:57 PM
armycop's Avatar
Sounds like the beginning of the engine seizing. Have it towed to a dealer asap. Don't try to run it until they check the cylinders.
Old Jan 27, 2008 | 06:58 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
oh boy doesnt sound good, how much of the 6quarts did it take? was there oil all over the engine?
Old Jan 27, 2008 | 06:59 PM
UCLA JK Rida''s Avatar
I was thinking the same thing...water got in under the missing oil cap...potential hydrolocking...no bueno.
Russ D.
racer83l's Avatar
USNjeep, do you have your JK serviced at your dealer?
I have heard stories a few different times about dealerships not replacing the cap after they do oil changes...
Old Jan 27, 2008 | 07:03 PM
do you do your own oil changes or do you have a shop or the dealer do it? it sounds like its hydrolocked to me. if the dealer does it, then you are probably covered as far as repair goes. like the previous post says, there has been a few stories of the dealer forgetting the oil cap. good luck!
Old Jan 27, 2008 | 07:04 PM
USNjeep81's Avatar
thanks for the replies, i always change the oil myself, and it took 5.5 quarts to hit the "safe" mark and yes there was oil all over the engine
why only just a click? what could be stopping it from turning over?
also, is any of this covered under warranty? i only have 7,000 miles on it....
Old Jan 27, 2008 | 07:06 PM
Robar's Avatar
I don't think it is hydro locked. That occurs by sucking water into the intake. If it was operated with out oil for long enough the engine probably got too hot and seized. Hopefully it is something much simpler and cheaper to fix. Good luck.
Old Jan 27, 2008 | 07:08 PM
USNjeep81's Avatar
what kind of story could i possibly give the dealer? im not good at just making up stuff, plus its still covered in mud at the moment...which makes it seem even worse...
