Freedom top question.
Old Mar 13, 2011 | 05:28 AM
klf's Avatar
klf
Default Freedom top question. Drilling holes!
Has anyone drilled into the interior thick portions of the freedom tops? I would like to mount a shelf overhead just in front of the visor. I am hoping the material will support screws. Thanks for your help.
Old Mar 13, 2011 | 07:52 AM
Four Low's Avatar
Post Bonding
I would recommend using fasteners called "riv-nuts" These are threaded inserts that install into the fiberglass with a rivet gun or expansion tool; then the fastener that holds the shelf screws into the insert. Otherwise, the fastener( screw) could loosen from vibration with predictable results. You can get the correct fasteners at Marine stores, auto body supply , and hardware stores. Show pix of your mod? Thanks
Old Mar 13, 2011 | 08:10 AM
klf's Avatar
klf
A big thanks. I have those at my disposal. I was worried about cracking around the holes or there not being a void above the thicker portions. I will post my results when complete.
Old Mar 14, 2011 | 12:11 PM
klf's Avatar
klf
Well I drilled into the tops today. No biggie. I installed the nutserts with no problem.
Old Mar 15, 2011 | 01:00 PM
klf's Avatar
klf
Default Cut to suit, beat to fit, and paint to match.
[IMG][/IMG]
Well here is my mod. You can never have enough storage space in a Jeep. It comes out with the freedom panel, no need to remove first.
Old Mar 15, 2011 | 04:41 PM
Four Low's Avatar
Post
Very Nice! I take it that you custom-formed the tin for the shelf, Jeep engineers, take notes...
Old Mar 15, 2011 | 04:50 PM
klf's Avatar
klf
Thanks. It was an old grey shelf from a steel work bench. I used a jigsaw, drill and, a brake. The nutserts worked great. The paint is krilon appliance epoxy coat. The stuff is awesome.
