Front Driver's Door Leak
I seem to have a water leak on that front door at the top left corner of the door where it meets the freedom top. Is there a simple fix to the leak or do I need to take it to a dealership?
I would start by taking the Freedom stops off and reinstall them but don't cinch down in the rear screws rear tight. Had this problem with mine and did the above and problem gone.
There's a guide floating around somewhere on the internet about how to fix water leaks....it's the guide the dealership will use unless they've got someone who knows a little more about it.
If you can't find it then pm me and I can email it to you. Sent from my DROID4 using Tapatalk |
Originally Posted by somguyss
(Post 3719710)
