Front Power Windows
Occassionally, my front power windows do not function. The back windows will go up and down, no problem. I had this once before and the car completely "died" a couple weeks after, it could not even be jumped and had to be flatbedded back to the dealer. Apparently, some sort of module had to be replaced. However, the window issue started again a few weeks ago. The problem will last for a day and then "go away". I brought the car to the dealer (I didn't want to risk it having to be flatbedded again) and they could not identify any sort of problem. Has this happened to anyone else? My Jeep is a 2007 Sahara Unlimited.
Thanks for any insight!
Can't help because my power windows (yes, I have power options) work very well. The one time I had a problem it was after I took the doors off for a few days. There was so much dust in the connector the passenger side wouldn't work. I cleaned the connectors and now they work fine.
Frankly, I'm amazed of the abuse I can give the Jeep with the doors off, and the power functions work perfectly when everything is put back together. Maybe that's because the doors are stored safe and sound when I'm doing the rough stuff?
So true
But no problems with mine whatsoever. Maybe because I rarely use them?
Always have my doors off or the freedom top off for that sole reason. I don't want to end up having to worry about the windows screwing up and not working.
Maybe we should help out, instead of mocking them. So what if shes a newbie. We all share a common interest and you should give advice instead of acting like real jeeper tough guys.
