Fuel Filter?
Old Jan 10, 2011 | 06:37 PM
Hellbound13's Avatar
Default Fuel Filter?
Do our JKs have a fuel filter and if so how often should we change it?
Old Jan 10, 2011 | 06:45 PM
ronjenx's Avatar
There are two fuel filters in the tank. Replace only when symptoms dictate it needs to be changed.
This is from the service manual:
Two fuel filters are used. One is located at the bottom of the fuel pump module. The other is located inside the module. A separate frame mounted fuel filter is not used with any engine.
Both fuel filters are designed for extended service. They do not require normal scheduled maintenance. Filters should only be replaced if a diagnostic procedure indicates to do so.
Old Jan 10, 2011 | 06:47 PM
Thanks. What are the symptoms to keep and eye out for?
Old Jan 10, 2011 | 06:48 PM
ronjenx's Avatar
Lack of fuel to the engine.
Old Jan 10, 2011 | 06:50 PM
Right but how would you know that? What what be the symptoms of that? Stalling?
Old Jan 10, 2011 | 06:54 PM
ronjenx's Avatar
Engine miss and stalling under load are early symptoms.
Low fuel pressure at the rail.
There are other things that could cause it, too. That's where troubleshooting comes in.
Old Jan 10, 2011 | 07:07 PM
Ah okay. Learn something new everyday!
Old Jan 11, 2011 | 12:29 AM
Red's Avatar
Red
Chances are, your check engine light would come on, and the code would tell you that there is a problem that could be related to fuel delivery to the engine. Then you would eventually track it down to the filter being clogged.
As far as changing it goes, unless you are using some gas from a questionable source, I wouldn't worry about it. The fuel has very little debris in it, and the filter will stay clean, probably for the life of your vehicle. Now, if you change the pump out, then I would change the filter as well, just to give it a new start, so to speak. Otherwise, this is probably one thing you don't have to worry about for a very long time.
Old Jan 11, 2011 | 06:24 AM
Cool. thanks!
Old Mar 14, 2019 | 08:55 PM
Chinasongz's Avatar
Default Fuel filters
Cool. thanks!
When you say the fuel filter should be good for the life of the Jeep, is that 100,000 or more?
