Fuel Injectors
Old Jul 1, 2019 | 05:57 PM
Amartin737's Avatar
Default Fuel Injectors
I bought a 2007 and can't register due to emissions for a P0202 code for the #2 fuel injector. Thinking about doing all 6 with remanufactured Bosch I found on Amazon. Company is NN Auto Parts. Any opinions or recommendations? It's got 175,000 miles and is a toy. Not my everyday driver.
Re-Manufactured OEM Bosch 0280158119 Fuel injectors for Jeep/Dodge/Chrysler 3.3L, 3.8L Set of 6 https://www.amazon.com/dp/B074W61GBJ/ref=cm_sw_r_em_apa_i_8LRgDbWAYRD0X
Old Jul 1, 2019 | 06:57 PM
ronjenx's Avatar
Have you done any troubleshooting to determine the cause of the P0202 code? It doesn't necessarily mean the #2 injector is bad. The problem could be in the injector's control circuit.
Old Jul 3, 2019 | 10:15 AM
Winyah's Avatar
I bought 6 omix-ada fuel injectors at about 170,000 miles and replaced them. I also was sure to clean the connectors real good because some looked a little corroded. It took care of my cylinder misfire code.
Old Aug 17, 2019 | 05:41 AM
Jennitran's Avatar
Originally Posted by Amartin737
I bought a 2007 and can't register due to emissions for a P0202 code for the #2 fuel injector. Thinking about doing all 6 with remanufactured Bosch I found on Amazon. Company is NN Auto Parts. Any opinions or recommendations? It's got 175,000 miles and is a toy. Not my everyday driver. Visit Autoguysland to view the best obd2 scanner in case you concern.
Re-Manufactured OEM Bosch 0280158119 Fuel injectors for Jeep/Dodge/Chrysler 3.3L, 3.8L Set of 6 https://www.amazon.com/dp/B074W61GBJ..._8LRgDbWAYRD0X
P0202 code is general OBD-II diagnostic trouble code (DTC) associated with the injector circuit. However, there are many reasons cause that issue. Hence, you should use obd2 scanner to diagnose to see what happen before changing anything. It may be failing or failed cylinder 2 fuel injector or poor/broken electrical connection,
