Gear question
Old Oct 4, 2014 | 08:40 PM
Germ's Avatar
Default Gear question
I have searched and can't find any info on this. I have a 4.10 ring and pinion from a 2013 jku rubicon with less than 1000 miles on it.
Will it work in my 2013 jku non - rubicon? Bolt on To the carrier, does the pinion have the same amount of splines for the yoke/driveshaft?
Old Oct 5, 2014 | 03:30 AM
PsychoCupcake's Avatar
Originally Posted by Germ
I have searched and can't find any info on this. I have a 4.10 ring and pinion from a 2013 jku rubicon with less than 1000 miles on it. Will it work in my 2013 jku non - rubicon? Bolt on To the carrier, does the pinion have the same amount of splines for the yoke/driveshaft?
The rear will work but the front will not. Your non Rubicon front axle is a Dana 30 but the gears you have will be Dana 44 front and rear.
Old Oct 5, 2014 | 08:22 AM
Germ's Avatar
The rear is what i have. What I'm not sure about is, is the spline count the same on the drive shaft yoke on the non rubi as the rubi? The rubicon pinion has 24 on it. I can't find any info on this via searching the web.
Old Oct 5, 2014 | 12:38 PM
Rebar-7's Avatar
So are you trying to regear to 4:10's ? Or what's the deal ?
Old Oct 5, 2014 | 01:59 PM
Germ's Avatar
Yes I'm going to regear it. Either 4.10 or 4.56. I have a 4.10 ring and pinion that came out of a jku rubicon with less than 1000 miles on it. I'm trying to figure out if I can use it in a non rubicon. If so all I will need to do is buy the front d30 4.10
Old Oct 5, 2014 | 03:44 PM
Rebar-7's Avatar
Oh ok, well the only thing I would think might be diff is the bolt holes in ring gear . Being that the carrier
In a Rubi is a locker . ( diameter wise )
Old Oct 6, 2014 | 06:16 PM
Germ's Avatar
Off topic, but how do you like the truetrac in your sig? Worth the money ?
Old Oct 7, 2014 | 04:27 PM
Rebar-7's Avatar
The trutrac is awesome well worth the money and there not that expensive ..
Hope dunnybunny dosnt see this..lol...
Old Oct 7, 2014 | 05:30 PM
Germ's Avatar
I don't know what that's about but I can imagine!! Lmao
I know a couple people that have them and like them but anytime I mention buying a truetrac people go ape and basicly say don't waste your money... But I'll probably buy one for the rear anyway.
Old Oct 8, 2014 | 02:57 AM
Mountain Man Tim's Avatar
I know I love my rubicons full locking dana 44s front and rear, so if putting a true trac on your rear gets you anywhere near that awesomeness on a budget, go for it. Nothing un****s a ****ed up traction scenario like lockers.
