Hard top cracks from fasteners
#71
I e-mailed Chrysler about the cracks
Rather than go to the stealership, a process I find even less appealing than taking a very cold shower, I e-mailed a Chrysler person who is apparently in a position to make a call on warranty items. He in turn contacted another Chrysler guy, who in turn relayed a message: "these hard tops can be taken off and put on with no reported problems and/or further cracking. Currently there are no repair kits for this type of concern. Torque on the fasteners should be 5-10NM." I suppose that, translated, this message is "too bad so sad your tops are cracked and you need to live with it." Oh well. I decided to use a plastic knob with a big flat bearing surface for the top, and to buy a roll of 1/16th inch neoprene adhesive tape for the bottom. You can cut the tape into two-inch squares, stick it to the bottom of the top's rail (after you cut a hole for the threads), and that takes care of the weak rail being pulled to far towards the rail. You can also double up the tape to equal 1/8 inch if your gap is bigger. Easy fix, and no scratching up the top of your rails! I like the idea of a metal washer/plate for the top, but if a gap remains then a reinforced top would simply pull the entire base towards the rail...if it is overtightened. Filling in that gap is the way to go.
#72
The guys that heat weld repair plastic body moldings should be able to (weld) that crack back up without to much trouble. We use that kit to repair polypropylene boats.
#74
I learned the hard way not to over-tighten the hard top bolts 2 Jeeps ago.
Since then first time I remove the top, I use over size washers to distribute the load. I have never had a problem with cracking the base when it came from the factory.
#75
I noticed this happening about 4 months after taking delivery. Took a trip to the dealership, showed them what was going on, and a week later I had a new roof. No arguing, no fighting. Guess I got lucky...
In the meantime I had some plates made up for under the bolts similar to what Woods sells. Haven't had an issue since...
#76
Ive got the same thing on one of mine. The crack is very small and only goes from the bolt hole to the interior of the jeep. I use a finger drive with a torx bit. I know that i dont tighen that too much. Its just a bad size washer i think that doesnt disperse the presure from the bolt enough
#78
Hey folks! I just happened to find the most visually appealing and simple solution to those factory bolts...check out the pics. Servalite is the manufacturer, and they are M8 x 50mm studs (I cut them down to 25). The bearing surface is 30mm across, far more than the factory bolt head size and bigger than most fender washers.
