Hardtop Leaking
Old Mar 23, 2012 | 05:35 PM
Elritchie's Avatar
Default Hardtop Leaking
My Freedom Hardtop, when raining leaks. the only thing is that is doesnt leak to the inside of the jeep. The water will get inside the passenger side removable top. Has anyone had this problem?? If so what did you do?? I was just going to replace the weather striping and see if that worked. Any feedback would be much appreciated. Thanks
Old Mar 23, 2012 | 06:28 PM
HippieHunters's Avatar
My hard top has done the same thing. Make sure the 2 pieces that screw onto the top right above your head are tightened down enough, that was my issue. If they are tight and it still leaks, you may need to replace the weather stripping.
