Why does the computer need flashing? What does it do for me?
i'm sure you can do it yourself. i paid to have mine done. i love working on my jeep but the hardtop wiring just isn't something i would get a lot of enjoyment out of.
Originally Posted by Spytec128
(Post 823567)
Just finished mine. The hardest part was trying to pull the plug through the firewall. Pretty straight forward. I guarantee you will learn alot about your JK from doing an install like this. You will see places you've only dreamed about.
Originally Posted by bosscj351
(Post 844322)
I've been planning on doing this wiring for a year now. Got the kit with the hardtop from the dealer but just haven't installed it yet. Maybe now I'll get to it! |
(Post 844322)
Soap it up...... :brows: I was struggling with that too and then remembered the dish soap. Don't be shy use plenty. Slid right through!!!!!!!!:clap: |
Any suggestions on step 16 where the two wires need to be released fron the connector? The older harnesses I was able to slip a small screwdriver in to release them, but I am struggling with this one and fear distorting/damaging the plastic block. Thanks!
I've seen where some cut the wire, leaving enough to tap into it from the new harness. I cut the wire and pulled it thru the top of the connector.
Fusebox Connector "G" and Instrument Panel Connector "C"
Both of these connections had existing wires where they were telling me to make the connection.
Was I supposed to tap into the existing wire or was I supposed to replace them? I tapped into them, but now I have constant power to the rear wiper, even when the key is off. Any assistance would be appreciated. |
connector C remove exisitng wire {usally same color]
replace with wiring harness connector this should be the connector closeest to the driver door. connector G will need part # of harness to determine |
