Sponsored by:
Sponsored by: DashLynx
Heat works only on passenger side
Old 11-26-2018, 10:56 AM
smorris67's Avatar
Default Heat works only on passenger side
2009 JK - heat only works on passenger side - blows cool air on drivers side
Old 11-26-2018, 11:42 AM
lifters's Avatar
My 2010 has the same issue, any thoughts on this?
Old 11-26-2018, 01:15 PM
jedg's Avatar
You likely have a plugged heater core or blend door that's not working. Do a search (google is best for this) for 'JK heat only works on passenger side' and you'll find bunches of references to this. Most cases it ended up as a replacement heater core.
Old 12-07-2018, 02:44 PM
EarlD's Avatar
Default Pass heat only
My 2012 does that when the coolant level gets low. My thermostat housing leaks. Found out by using a rental pressure tester from autozone. For temporary cold relief raise front wheels about a foot and add coolant to radiator inlet.
Old 12-08-2018, 09:56 AM
EarlD's Avatar
Default Here's why thermostat housings leak.
Notice how flat the old leaky oring is on the right after six years. The new one of course is full and round.
Old 12-08-2018, 02:37 PM
Rednroll's Avatar
Is that O-ring part of the housing or the thermostat? Just curious as to the reason many replace the entire housing rather than just the thermostat.
Old 12-09-2018, 10:03 AM
EarlD's Avatar
Default Thermostat oring
The oring is just pressed in the groove on the one from RockAuto. They're sold with or without the housing.
The oring sure fixed my heater issues though.
Old 12-09-2018, 11:26 AM
Bigben42's Avatar
My 2012 did the same thing. I had to replace the heater core last winter. I still got great heat this winter. Theres a thread on here how to replace without having to remove the whole dash if thats your problem.
Old 12-15-2018, 03:10 PM
Jay2013jk's Avatar
Agree with jedg... go for the blend air door actuator, it is bolt on plug and play... you find utube videos on replace it and also the heater core .
Old 12-29-2018, 08:02 AM
sjm2011's Avatar
Just dealt with this problem the last few weeks. Daughter bought a 2011 Wrangler that she loves. We had to fix a few things here and there but for the most part has been a good vehicle. Cold weather hit here about 6 weeks ago and she discovered little to no heat out of her driver side vents. I checked coolant levels, thermostat, etc and the only thing we noticed was that the radiator and reservoir seemed to have some gunk. Took the jeep to our local mechanic and he did a thorough coolant flush. Still no heat on the driver's side. I warmed up the jeep to operating temps and hit each one of the heater core hoses with my IR thermometer. Inlet temp was around 180 degrees and oulet was about 90 degrees. Figured the heater core was plugged and would need replaced. I backflushed the heater core with the garden hose. Surprisingly I didn't get much gunk or discolored water and had good flow. As a last gasp effort, I switched the input/output hoses to the heater core. Topped off the radiator and took it for a test drive. Drivers vents had more heat than before but still not 100%. My daughter drove it this way for 2 or 3 days and whatever blockage was in the heater core must have come loose when we reversed the flow direction. She has full heat now to all vents. I realize that whatever was blocking the core is now in the coolant but doing another flush is much easier than changing out the heater core. Fingers crossed that it continues to work.
Montego (02-08-2022)
Quick Reply: Heat works only on passenger side
