Heater Core replacement
Could anyone out there please let me know what the correct replacement heater core is for a 2009 Jeep Wrangler Unlimited Sahara 4 door, six cylinder 4x4? A link would be great if possible. Thanks!
Search the internet for this part number: 68004193AB
Originally Posted by ronjenx
(Post 4333962)
Wish the job to replace wasbas easy as it is to get a response. Looks to be a very involved process! |
Originally Posted by Kosta0601
(Post 4333984)
Thank you!!!!
It isn't hard if you want to do it the easy way. Just cut the incoming and outgoing lines to the core, remove the bracket under the dash by cutting it, cut new lines to the same length, secure the core with heater hose and clamps, then pop rivet the removed bracket back into place using some small c channel. I fixed mine this way and have not had a problem. When it goes again, it will be another easy fix.
Awesome......Thanks!!!
Are you guys using 5/8" heater hose for connecting?
Going to be doing this hack very soon |
Originally Posted by BlkSlvrJK
(Post 4335649)
