Help with dynabeads
OK just got my new 35x12.5x15 pitbull rocker radials put on yesterday. Had clearance issues with the stick on weights so decided to try out dynabeads. I seen dynabead chart recommends 8 oz for my size tires. Went to loocal tire shop that Carey's dynabeads. He has 6.5 and 10 oz bags. I told him I wanted the 10 and he says his charts show I only need the 6.5 oz. He wouldn't even look at chart I had on phone. So the 6.5 bags go in. Seemed all good till I got on interstate today. Can't go over 60 MPH. So my question is will the extra oz of beads I wanted in first place fix the problem? If so Is it worth going back to shop and argue that he needs to break tires down for free and add more beads? Thanks guys
Check out the tire charts on w w w. innovativebalancing.com, they say 6oz as well.
Go with what dyna beads say! I use these in my shop and if done correctly they work great!
The chart with your size is 6oz.
I'm sorry it is 8 yes I would make them fix it! I would here! But I do motorcycles and tires are serious business!
Originally Posted by Jethro0417
I just went there. It shows 8 oz for 6 ply tire in my size. |
OK guys thanks for input. Go down tomorrow and try and argue with shop. My tires are known for being hard to balance should I put a little more than 8 oz or u think 8 will do the trick?
If the shop won't help you could get the smaller size beads and add them through the valve stems yourself.
