Help Hot Transmission P0218 and P0740
I have a 2008 JKU with 175K miles. I had a P0740 code which is TCC Solenoid TCC not locking the Torque Converter. I replaced the Solenoid Block yesterday which should have fixed the problem. Today as soon as I was on the freeway my CEL came on again. Same code P0740 and a new code P0218 which is hot transmission. My Hot Oil warning didn't come on. It has come on in the past.
Could my Torque Converter be bad since replacing the Solenoid Block didn't fix the problem? If the TC is slipping at high speed would that make my Transmission overheat and cause the P0218?
3.8L automatics in JKs have woefully inadequate transmission cooling. Many have burned to the ground from transmission overheating causing fluid to pour out of the fill tube and onto the exhaust. I'd recommend you get a trans cooler fitted ASAP. Any properly installed parts store cooler will do the job.
Is your Jeep shuddering as the TC locks up? The 42rle is a piece of garbage that has problems nobody is able to fix. This is just the beginning. Wish I had a fix to advise but there are none.
No shuttering at all. Can't even notice that there is a problem. The only way I know there is something wrong is the CEL comes on after when I hit 70 on the freeway. I bought the B&M Transmission Cooler and will install it on Friday to get my temps down. From what I have been reading the TC malfunction can cause excessive heat.
jagarwal (08-28-2022)
