HELP on Install for interior???
Old Oct 13, 2010 | 01:38 PM
kevinss2001's Avatar
Default HELP on Install for interior???
i bought one of these--
.ebay.com/ebaymotors/JK-JEEP-WRANGLER-ADD-BIN-STORAGE-NET-DASH-POCKET-OEM
has anyone installed one and if so do you have directions? I have only had my jeep for about 4 months and have not had anything really apart yet--let me know and thanks in advance.
Last edited by 07rubisteve; Oct 13, 2010 at 02:46 PM. Reason: No direct links to Ebay/Craigslist etc as per Forum rules.
Old Oct 13, 2010 | 01:48 PM
VaNomad0530's Avatar
I'm sure someone will chim in soon on how to install it. I think I've seen, on another thread, a write up on how to install the daystar switch panel. Same exact spot so it should be the same steps...you could try doing a search on that if you're having trouble finding directions May be just as simple as using a flat headed screw driver and popping out the panel....buuuut I'd check first to make sure
Old Oct 13, 2010 | 02:12 PM
Coley's Avatar
pull the top two corners straight towards the rear of the jeep. Not too far or forcefully. Once it tilts back, you'll be able to lift the whole panel straight upwards and out.
Old Oct 13, 2010 | 02:33 PM
SIDsjeep's Avatar
Veteran: Coast Guard
Originally Posted by GoodysGotaCuda
pop out the old, and pop in the new. Credit card or something behind it to get it started coming out. Has slots on the bottom that go in first if i remember right. Maybe a whole minute job
a spatula works great
Old Oct 13, 2010 | 02:38 PM
Ghost63's Avatar
If the new one came with the metals clips your gloden, otherwise you will need to swap them around. Take your time and go easy with the clips and you will be fine.
Old Oct 13, 2010 | 02:42 PM
dgnr8's Avatar
This video will show you how to complete the take off and install in less then a couple of minutes
hxxp://www.youtube.com/watch?v=bebj-0ynPsg&feature=related
Old Oct 13, 2010 | 05:51 PM
just took it out and put the new one in--took all of 30 seconds--thanks for all the help.
Old Oct 13, 2010 | 06:14 PM
ssease's Avatar
I need one of these! Glad you got it in ok!
Old Oct 13, 2010 | 06:35 PM
they are very easy to install--cheap on ebay--about$30
I plan on using it for my cell phone and ipod--especially when the doors are off
