HELP , No start , stranded
well i've read all the threads and nothing is working for me , just looking to some insite to avoid the dealer if possible (out of warrante).
Was running fine, went to the store. Got in it to leave and nothing. It clicked but no start. I worked the key a few more times and it started , ran for about 3 seconds , then died. Did that 3 times and now not even that. I replaced the battery with a brand new one just now and still nothing. Wont start in neutral or after moving the shifter (auto) . No codes, beat the starter with a hammer, nothing, just clicks. Tried to run a temp ground wire from neg terminal to engine block and to frame, nothing. Pulled all the started/ign fuses and nothing.
WTF! And on top of all that I missed the first half of the JETS game!
Help me! puleeezzzzeee
Maybe if the starter doesn't disengage or theres a malfunction, it kills the rest.
Maybe tap on the starter some more , are the cables corroded,gunked up? Maybe wiggle em clean them and check for a bad connection.
I did push it forward into the parking spot . I guess I'll be pulling the starter in the morining and have it checked out. The cables look ok but its worth a shot.
