HELP , No start , stranded
well i've read all the threads and nothing is working for me , just looking to some insite to avoid the dealer if possible (out of warrante).
Was running fine, went to the store. Got in it to leave and nothing. It clicked but no start. I worked the key a few more times and it started , ran for about 3 seconds , then died. Did that 3 times and now not even that. I replaced the battery with a brand new one just now and still nothing. Wont start in neutral or after moving the shifter (auto) . No codes, beat the starter with a hammer, nothing, just clicks. Tried to run a temp ground wire from neg terminal to engine block and to frame, nothing. Pulled all the started/ign fuses and nothing. WTF! And on top of all that I missed the first half of the JETS game! Help me! puleeezzzzeee |
Undo the positive and neg cables, touch the ends together. Then hook it back up,see what it does.Thats about all I got since you already did the other stuff.
nope, nothing there either. I'm thinking possible starter... ? But why would it have run and die like that?
Maybe if the starter doesn't disengage or theres a malfunction, it kills the rest.:dontknow2:Maybe tap on the starter some more , are the cables corroded,gunked up? Maybe wiggle em clean them and check for a bad connection.
I'll pull it off tomorrow and check the cables. How do I know if its bad? Do i have to just replace it and hope for the best?
Bring it into an auto parts store, they should be able to put power to it and tell.
the starter is clicking or no? Id start at the battery, as you have, and work out from there. Im thinking check the fuel pump, relay and fuel filter. Hopefully its not a bad ECU. :hmm:
Have you tried rocking the jeep abit forward and back abit and try to start? Throwin everything i can think of right now.
Sounds like a combo of things. Battery sounds good as its newer. Loose or bad connections, starter and maybe alternator... damn.
Originally Posted by shoe1724
(Post 2526133)
Originally Posted by mkjeep
(Post 2526134)
| All times are GMT -8. The time now is 01:21 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
