help pvc valve
i just remove my pcv valve (zip tie) did not work, any how my problem is the half of the rubber seal of the pcv valve went in side of the valve cover ::eek2 1 question do i need to remove the valve cover to get it out if so can i reused the same valve cover gasket 2question or just leave it in side
than you
than you
I would rather see you have a leaking valve cover because you reused a gasket, instead of a completely destroyed top end. Get the rubber piece out, don't even turn the motor over.. Reuse your gasket and if it leaks a little you can at least drive it safely to the auto parts store and you'll already know how to get the valve cover on and off! just my.02
