Help removing bolt?
Old Mar 7, 2013 | 10:09 AM
Steven4est's Avatar
Default Help removing bolt?
Broke 2 star keys trying to get these bolts out and then they stripped. Sprayed liquid wrench inside and out and tried removing with channel locks and they wouldn't budge. Anyone have any advice on removing these without damaging the current threads?
Any help is appreciated thanks!!!
Old Mar 7, 2013 | 10:18 AM
FoxRacingJMC's Avatar
Small drill bit and drill em out?
Old Mar 7, 2013 | 10:33 AM
Offroad_Elements's Avatar
Former Vendor
Left hand drill bit, works like a charm.
Old Mar 7, 2013 | 10:44 AM
Steven4est's Avatar
I'm guessing if I drill a hole through the middle it will weaken the bolt enough so I can turn it? My other idea was to weld a socket head to it and then wrench it out. This thing is really in there, anti seize for sure next time it goes in
Old Mar 7, 2013 | 10:48 AM
Freewill's Avatar
The bolt in the second photo looks like you could get a ViceGrip on it.
Old Mar 7, 2013 | 10:51 AM
Usually that's the first approach when it comes to trying to get a stripped bolt/screw out....outside of ripping it out and damaging the threads.
Old Mar 7, 2013 | 10:52 AM
finfreeze's Avatar
Weld a nut to it.
Old Mar 7, 2013 | 10:53 AM
Welding a nut to it is a good idea as well
Old Mar 7, 2013 | 11:03 AM
jadmt's Avatar
JK-Forum Ambassador
most likly has red locktite on it. heat it with a torch and give it a little wack with a hammer and it should come out.
Old Mar 7, 2013 | 11:14 AM
Jp3792's Avatar
Weld a nut on and put a breaker bar on it
