Help! Starter or Key Switch???
Daughter stopped to get air in tire, jeep wouldn't start. Makes a click but won't turn over. Battery and fuses good. 2012 JK auto. 50k miles. Also noticed the steering wheel doesn't lock with key out. You can turn wheel freely. Any help would be appreciated!!!!
How can you be sure the battery is good? They are known to have a sudden death in our jeeps and do wacky things when they die. My guess is a bad battery. Have it load tested.
Because I had cables on it attached to my running vehicle. Not a continuous ticking like a low battery. One click
Sounds like the shifter. https://www.jk-forum.com/forums/stoc...nstant-253187/
Originally Posted by 510rider
(Post 4261290)
Mine did the same thing when the battery died. Mine is also a 2012 and it took a while for the old battery to get it going, i think 30min with jumpers. Same symptoms the OP is describing. Got a battery at costco and all good to go. This was a about 2 months ago.
Mine acted the same way. I replaced the battery and it still did the same thing. Mine was an automatic and after a little research I pushed forward on the shifter handle and it would start fine. It would also start in neutral.
Tried pushing the shifter forward and putting it in neutral. No luck. The battery was showing 9.78 Volts on the multi meter. I will try charging it up tomorrow.
(Post 4261915)
Mine started doing the same a couple months ago. It was the battery. Mopar battery was only 18 months old!
