Help with Transmission Fluid Line
Hello. New to the forum and I have a 2008 Stock JK. The starter was going out so I changed it out this afternoon. In the process, I accidentally hit the transmission fluid line near the lower bolt and the line popped out of the side of the transmission. Needless to say I was surprised when fluid started pouring out on my initial startup (new starter is great, btw). My question is, how does the line go into the transmission. The line itself has a little flair on the end and it appears there is a plastic piece that holds the line. The plastic piece does not appear to be broken but it does not seem to hold the line very tightly (and may not need to).
Does anyone know how the fitting works? Hoping to not have to replace the whole line. I cant tell how it fits so any experience/advice would be appreciated.
It snaps in, held in place by a wire clip. Pop off the plastic cap, then push in the metal line it until you feel it click. If it doesn't click into place and stay put it's likely the clip has been damaged or is not in place. Lisle makes a cool tool for removing the lines that won't damage the wire clips.
Thanks. I finally got it figured out and fixed. Doesnt look like there was any damage to the line and I am not sure how it popped out. I removed the retainer ring, put the line and ring back it and it is holding and not leaking.
