Which Hitch?
I have the receiver already on the jeep and plan on towing a small utility trailer.
My question is do i need to get a hitch that drops down or do i need one that is straight?
I am referring to the piece that has the chrome ball on it ( sorry if i don't have the terminology correct )
So, basically i have the 2 inch reciever on the jeep, and this
40-1/2" x 48" Small Utility Trailer - 1090 Lb. Cargo Capacity
What else do i need?
Thanks !
Thanks !
You should only need 1-2 inch drop as stated before, if you have a lift or larger tires that will adjust the drop you will need to get also a lock/ pin the best ones I've found are made by Reese and you can find them pretty much at any auto parts store.
Thanks !
Thanks !
