Hope for your hinges...
Basically as described above, bi-metal corrosion occurs because a aluminum hinge was placed on a steel door, engineer should be stoned for such a stupid design flaw. And not the good stoned, maybe that was the issue. I digress, over time the aluminum reacts to the steel causing a bubbling and flaking of the paint causing the two to lose bond and creating quite an eyesore.
Originally Posted by Xxbodhixx
I'm I northwest Texas. Here's a screen shot from last year....
Also, was about to inquire on this topic myself. My hood hinge is pretty bad. Is the integrity of the hinge itself compromised or is it just the paint bubbling?
Originally Posted by teh215
Thanks. I assumed it was something like that. Are the hinges aluminum or something?
Reason I ask is cause if they do remove them from the door and then reinstall the hardware I think the tork bolts would remove some paint on the hinge while tightening.
Originally Posted by jkohn3r
I have this problem with two of my hinges. I would think that putting some kind of plastic or rubber in between the two, that it would allow the door to slightly move resulting in sagging doors. What I want to know is if they remove the hinges from the door when they do this procedure?
My '08 had this problem on the right front top hinge. I showed it to the service writer when I was getting an oil change. He said hold on and he made a phone call. Came back and said to come back the following Monday and he'll have them in and will replace all 4 doors. Came back and they did it for free. Even gave me an Enterprise rental (2010 Ram) while it was being done. I was happy.<br><br>
Gonna keep an eye on my 2012 too.
Originally Posted by basketmaker
My '08 had this problem on the right front top hinge.* I showed it to the service writer when I was getting an oil change.* He said hold on and he made a phone call.* Came back and said to come back the following Monday and he'll have them in and will replace all 4 doors.* Came back and they did it for free.* Even gave me an Enterprise rental (2010 Ram) while it was being done.* I was happy.<br><br>
Ok, just got my JK. Not only is Chrysler being cheap @$$'s by not replacing the hinges, they aren't even attempting to blend paint. Paint is matched by color code and sprayed ONLY to the hinge. My Jeep now has 10 hinges that are the same color code as my Jeep but not the same color as my Jeep. Oh, and only the hinge half that mounts to the door was painted, not where it mounts to the body. This shows the colors clearly don't match. I am told it is because it's new paint with more clearcoat and as time passes they will begin to match. Unacceptable. I immediatly called my case worker... Out for the weekend and no one can help me until Monday. I'm LIVID. I feel my Jeep looks worse than it did on Tuesday when I brought it in and that they devalued my vehicle.
