Horn not working
Horn not working
I just flew into NY and drove my new (to me) 2007 JKU home. One of the things that needs attention is the horn doesn't work. I checked the fuses and they're fine and neither horn is getting power at the horn. Buddy seems to think its the switch which is part of the airbag. I first thought of clock spring, but there I no check engine lights and no codes. Thoughts?
My 08 is the same way. My horn doesnt work either and I have also checked my fuses and they were OK. I'm not sure what to check next either. Its beeps when I lock it up. I'll be keeping an eye on this thread.
I have an 08 and when the horn is pressed I can hear the relay click. I changed both fuses which looked fine. Still no horn when pressed, no horn when fob is used to lock doors and no horn on the panic button either. Where do I go from here??
Look at the horn and see if it is clogged.
Unplug the connector and with a meter, see if power is getting to the connector. Also, see if the connector has a good ground connection.
Since cvfd525 can hear the horn relay click when the horn button is pressed, the problem isn't the clockspring.
