how to know if hydrolocked
Old Oct 28, 2013 | 12:35 PM
2009rockymountain's Avatar
Another quick question..with that water, I recently changed dif fluid to amsoil.I was too lazy to extend breathers.
Off chance I got some into the hose past the cap on top..will it burn off? Being new fluid and caps still on?
Thanks
Old Oct 28, 2013 | 12:37 PM
kh202's Avatar
Thanks
Check to see if the fluid is milky at all. If it is, drain and refill. Chances are if you just flew thru it and water hit the windsheild, you're ok. If you got stuck and are sitting in it up to your mirrors, that's when you'll really run into trouble.
Old Oct 28, 2013 | 07:59 PM
Matthewd5's Avatar
Drive on road a bit since.seems ok So thankfull im educated enough to know to turn it off and ring water out of air box.
I've never seen any reference to wringing water out of the air box, could you please elaborate?
Matthew
Sent from my iPad using JK-Forum
Old Nov 27, 2013 | 07:37 AM
Matthew
I got out of the hole..turned jeep off..took air filter out..took microfiber cloth I leave in jeep and let it soack up water. Rung it out a few times
